Location of spring on model 13WF91AP010, 2011
MikeT1977
Just sharpened the blades and changed the belt on the deck of a Cub Cadet 13WF91AP010, 2011.
After completing I found a spring on the garage floor that I do not recall removing.
The length of the spring excluding the hooks at each end is 4". Please see picture attached for image of spring.
I'd appreciate any insight on where the spring is located on the mower so I can reinstall.
Thank you,
Mike
MikeT1977
Thanks for the info. That is definitely the part. You got me to the right area on the mower, and I appreciate the help.
The connecting points aren't straight forward under the mower. I'll try to do a little more research.
