Linkage connection.
Jakehintz1
I have a 2016 simplicity regent 44inch/23hp briggs intek.
Can someone please show me a picture of how the linkage on the left side below the carburetor hooks up. It's the one with the little white plastic clip that hooks into the lever. I had to remove it because it must have sucked something into the car and was running horribly and blowing tons of black smoke. I removed it, cleaned everything. One of the jets was clogged shut. I used a bristle off a wire brush and cleaned both sides. Reassembled everything and the mower fired right up and runs great but I noticed that linkage rod came disconnected from the white clip. I'm not sure I had it correct when I put it back together but it seemed like it fit right. Thanks in advance. IMAG0092.jpgIMAG0091.jpg
