Limited Slip differential on Husqvarna YTH2242TDRF
C
chinthay
Guest
In Australia, this model of Husky lawn tractor has a limited slip diff. which is good when your on a slope, but is too aggressive when I am going around my fruit trees on a tight turning circle (about 1 metre radius). It tends to lock the drive to both rear wheels and consequently the inside wheel tears out the lawn. Is there a solution.
