lgt 2654 kolher courage 26 hp 725 cc
Chuck1953
I need a carburetor kit with float. I can't find one the carb is a walbro LMC 3 0452 320532 8 or S not sure
also a carb kit for walbro LMK 75 1249 1205393, THANKS
If you posted the actual model and spec numbers the engines someone like me can look up the Kohler carburetor kit PNs. I can't pull up either of the Walbro carburetor on the Walbro website. They only one LMK and no LMC carbs.
