lgreene999
I have a scag mower that is having a problem keeping the battery charged. The battery is new, the alternator is new and the voltage reg is new. Checked the output of the alternator and is between 13.8 and 14 volts. If the mower sits for a few days the battery stays charged. It seems to loose charge when the blades are engaged. Showed no draw on the battery when the mower is off. The year is 2006. Model # is STC48V-26BS, the motor model is 44P777 Type 0115 E1. Thanks in advance for any help.
