I'm new to this forum so someone can point me another direction if needed. I just purchased a used - but very good condition Hustler Fastrack with a 54 inch deck and OEM powered blower bagger.
The deck is just about an inch off level. Its very obvious just looking that the deck is out of balance - the chain on the left side is loose because of the weight of the blower on the right side (stepping the deck to counter-balance the weight of the blower brings it back to level). It looks like there's an adjustment on the right-side linkage (a bolt running in a slot with a set-screw bolt as well) - but the available adjustment has already been used as near as I can tell. In addition, any adjustment made here will be an over-adjustment any time I take the bag and blower off (which I plan to do most of the time).
Any suggestion?
Any suggestion?
