chance123 said:There should be adjustments for how far each hydro pump is moved. When it is in the neutral position, does it creep? (move)
chance123 said:I am not familiar with your machine, but there should be a link between your L & R control handles and each (L & R) hydro pump. Jack the drive wheels up off the ground, start the engine, and adjust these linkages until the wheel(s) stop moving when your hands are off the control handles.
