Attachments Legacy XL 60" Dozer Blade
The Gage
I just purchased a new Legacy XL tractor with 60" mower. I would like to buy the 60" hydraulic dozer blade, but I need to make sure the tractor with the dozer blade attached will fit into my shed. Does anyone know how many inches the 60" hydraulic dozer blades extends in front of the tractor? I asked the dealer, but he did not know or find the information in his dealer records. Thanks for any help.
Jaws
We need a bigger boat !
You probably need a bigger shed ... add about 2 to 3 feet in length for the blade .. .. she will be huge, and then there is maneuvering room and the future (more stuff) .
Or this ..The dealer should know the length of the mounting bracket and how far it projects from the tractor mount holes .. I'd go for a much bigger shed ...They can never be too large ..
Thanks for the response. I received an email from Simplicity support today letting me know that with the 60"dozer blade attached, the length of the tractor and blade is 105" (81" for the tractor and 24" for the blade). Since my current utility shed is 120" x 120" inside dimensions with an 8' door, the tractor with blade will fit.
