Hello, all...
Next issue to rise up...leaking fuel from bottom of the carb. Statesman...16.5/42...model# 13AN694G016
There are two wires connected to a plug under the carb....this lil metal area has a black plastic...inner. This small cylindrical....thing...where the wires plug into the bottom of the carb...leaks. I have a shut off valve on the fuel line....still leaks.
I can't find the carb in the parts schematic....and the carbs i seen in the replacement parts area...do not have this lil cylindrical plug thing on the carb.
I'm sure the lil part is replaceable...though I wouldn't know how to do it....it's not threaded onto the carb...looks like it has four small tabs that're crimped onto the...bowl?
I can get a pic if you all need...or is my clear as crystal description enough?
Thanks for your time.
