Lazer AS Throttle Adjustment
LazerAS
Hi,
I have a 2008 Lazer Z AS with the Kohler Command Pro 25 engine. I need to find the proper adjustments, and settings for the throttle cable, and any related linkages. There are several locations that the throttle cable and return springs can connect to. I also need help with the choke cable connection. I have replaced the throttle and choke cables. I thought that the throttle cable was stretched because the lever wouldn't raise rpm until about half way, apparently i was wrong. Basically, I don't know where everything is supposed to go to in stock configuration, or why there are 4 connection points for the return spring. A picture would be great, I searched for a diagram, or a site that showed the connections, but came up empty handed. Even Exmarks site was pretty useless.......
