I have a john deere la120.
I have tested the battery and it is good, I have tested different switches and checked fuse and that is all good. It would not even turn over. I tested the solenoid and got nothing. I tried to jump start the solenoid and it turned over. So I replaced the solenoid and it resolved the issue. We'll, I brought the lawn mower over to do a oil change and after I got done with oil change. Got on to the lawnmower to start it up and did the same thing, it did before I replaced the solenoid. Nothing.
So I was lost for words, well. I tried to jump start the new solenoid and it worked, and I only thought the solenoid started up by a jump by touching the 2 ends together if it was junk. So now, the new one is doing the same thing. I tested the solenoid with the multimeter and it showed it was good. I even went and got another solenoid and still nothing but get a very slight click when turn key but very slight click.
Lost, and thought what is going on please.
Thanks
RES68
Thanks
RES68
