I have a 2006 MTD push lawnmower, model 11A-589B795, with a 6HP Briggs and Stratton engine. This spring, the engine would only start with help of starter spray, run OK for a few minutes, then the speed surges up and down and then dies. The interesting thing is that it will restart almost immediately, and run for another 5 minutes until it dies again, which greatly increases the time it takes to mow the lawn.
Here is what I have done to date:
1) Removed the plug at the bottom of the fuel bowl, cleaned with carb cleaner and blown out with air (multiple times)
2) Drained the gas tank, replaced gas with fresh gas and fuel system cleaner added
3) New spark plug
4) New air filter
5) Bought a carb rebuild kit from B&S - this carb evidently does not have diaphragm because there was not one in the kit, just various gaskets and new fuel metering pin. Removed carb, cleaned with carb cleaner, reassembled with new gaskets and fuel metering pin.
6) New fuel tank cap (loosening or removing the cap when it starts to surge and die makes no difference)
Any other ideas to try before I replace the lawnmower? I know this has been covered already a thousand times. Thanks in advance for your input.
3) New spark plug
4) New air filter
