Hi thanks for your relply, I have uploaded some pictures of numbers from under the seat and a black plate above the exhaust there is no throttle cable adjustment. On the carb there is a orange adjuster you can move to either of 2 positions as in The pictures. From the throttle pedal there is just a metal rod that goes to the belt to add tension, is there some sort of clutch on these? Thanks for your help
