Lawnboy Dura Force 6.5hp
gmartin
My, Lawnboy Dura Force 6.5hp won't start after I have been using it & empty the grass catcher. I pull & pull, take out the spark plug replace it with a new one, most times it won't start I have to use my backup mower which is a Snapper. I have not been able to solve this problem, I have taken it to the repair shop only to continue having the same problem. Anybody have any suggestions? I,m at a total lost. I actually have 2 of these mowers & they do the same thing.
Briana
Welcome to LawnWorld!
We moved your thread to the Lawn Boy forum.
LB8210
Right when you have the no start, check for spark. It sounds like you have a bad coil. It shows up with a hot motor that is shut off and the coil has a hot soak as heat builds up under the shroud with no air movement , causing the failure to show up. After market coils are available for around $20 including shipping.
jp1961
I would also check the crankshaft seals, a common culprit when it is difficult to restart when hot.
Jeff
D
DSepe
Guest
Have the same little mower...love it. Hope you figure it out soon
