lawnboy 10323, ser. 24000.....
EdBrown
Have had this LB for some time. Did not run it last year. Started up and runs well, but self-propelled not working.
Is it adjusted in the SP cable, at the top of the mower? Seems like not enough tension when bale is pulled up. Thanks very much.
Ed
Belt slipping as it is worn out? Also the friction rubber bushing can wear out, shaft will turn but wheels will not. The bushing are on each wheel, usually one will work, not likely both failed at the same time.
Hi Ed,
Did the spring at the end of the cable come off the stamped steel bracket? It is possible that happened.
You've got a 2004 10323, the last year made.
Regards
Jeff
