Engine Lawn mower 260
Nina Joy
My John Deere mower 260 will start and run about 30 minutes until it gets warmed up and then it will just stop like it is out of gas. I can let it set for about 10 minutes then start it and run it for another 10 minutes. No one can figure out the problem. Need ideas bad.
talley2191
Rule out a vacuum issue associated with the filler cap? have you tried to run it with the cap off? Very simplistic first step.
