About to put this back together. It is a Model# 13AM660F205 with 39 inch cut. I still need the grass deflector chute, mounting rod and spring. The original part numbers: 113076, 096438 and 097972. As well as the Left hand belt guard, part # 113209. If someone might have these, please let me know and what you would want for them. Thank you
#2
Boobala
Found this, seems they have the chute, but NOT some other parts, CHECK the diagrams, and some part numbers have been superceded CHECK CAREFULLY !
You were my first contact on this site. You sent a pm reply and I could reply to it. I didn't know I had to go into my settings and change it to pm to send one.
By the way, you wouldn't happen to have the grass chute, rod and spring?
