I have had one model of F series that came with a mulch fan (model 10420) and I didn't notice it being of any use, so I removed it to. I have no experience with those Duraforce engines, but I know they have a reputation of having finicky carbs. Many folks have had success at modifying those carbs by installing a bigger jet and a different throttle plate to take care of that lean surge issue. If you are interested I think you can do a search on this forum, or Mytractorforum.com for the details on just how to do the mod. Those modern plastic carbs are notorious for warped mounting flanges so you might want to check that as well. I have heard a few owners report that fixing the warped flange was all that was needed.
