Two-Stroke
- May 7, 2010
- 23
- 1,594
I just bought a well-used model 10415 (circa 1994) for $30. When I got it, the engine was running unevenly -- it was necessary to choke it every 15 seconds or so to keep it going. I figured that it was running too lean and then noticed that the needle valve was screwed all the way in! I turned it out a full turn and everything seems peachy with the engine -- a fine Lawn-Boy two-stroke power plant, the best thing about this mower.
Here it is from the top:
This is a side view:
I don't like all the clutter on the handle. It has a blade brake as well as a throttle control -- plus that huge piece of sheet metal that seems extraneous -- don't they think about weight?
Anyway -- I like the mower. The only real issue is the left rear wheel -- at worst I'll have to replace it.
