Picked up a 1998 Lawn Boy Gold Pro DuraForce 6.5 Model #10525 for about $40 since it wouldn't run. I could tell someone has already been into the thing so please keep in mind I have no running configuration to work with. It had the completely wrong plug, was missing a couple pieces, and had been someone creatively assembled in certain areas. I got all of that straightened out and just need to heli-coil one CDI mount point and it'll be all good then.
The problem I still have is no throttle control and it seems to surge. With the throttle on 'slow' vs 'high' I can't tell a difference in engine note/rpm. When I push it into choke I can hear the engine note changing and the RPM lowers a little but it doesn't chug. I have not checked the butterfly in the carb to see if it's 3/32 or not. Since I don't have any throttle and it surges all the time I think I probably have an air leak somewhere in the gaskets that sandwhich the carb to the head/reeds.
When I was pulling the carb off the 2 gaskets that bolt the carb to the heat shield and then the heat shield to the head ripped or separated. I used some regular gasket material like what you would user on a carb to intake gasket on a car and cut new ones but I don't think they're sealing correctly. I ordered new gaskets for the Air Box to Carb, Carb to Heat Shield, and Heat Shield to Intake but the Heat Shield to Intake gasket was wrong. The one that was on the mower was a square port gasket and the one I received was a round gasket like what you would put on the carb to airbox. The part # was 94-5795 and I ordered it from partstree.com. I'll double check how my home-made gasket sealed when I pull the carb back off this weekend. If it looks like it sealed good and no indications of it leaks then I'll throw it back on. I might find some spray gasket prep/tacky stuff just to make sure.
In my quest to get the throttle to respond to 'high' vs 'low' I adjusted the governor up and down a couple clicks. Eventually I got it to where it ran at a relatively high RPM all the time but the throttle still did nothing. I think I have to adjust that down a few clicks as I think it's over-revving and bouncing off the governor now too. Either way once it got to the point where it was running on high RPM's I fed it some grass and it seemed to run pretty good. It barely dropped RPM unless you went into 6" tall grass and even then it was good until the grass balled up under it. It did smooth out some when I hit the tall grass but I could still tell it was surging.
So, where should I proceed from here?
Things I've done so far:
- Replaced incorrect spark plug with an Autolite 2976 (couldn't find the NGK locally) $4
- Rebuilt/Cleaned carb $4
- Replaced 37.5 Pilot Jet with a 42.5 Pilot Jet (Briggs 803801) $6
- Replaced CDI with an identical looking one $15
- Replaced Air Filter $8
- New 21" gator-style blade $24
Things I've yet to do:
- Check butterfly in carb to make sure it's 3/32" hole
- Replace home-made carb gaskets with OE gaskets except the intake to heat shield gasket
- Helicoil one of the coil mount points that stripped
- Pressure wash it good
I will say that it has some pretty impressive power. Considering my old home despot special mower would bog down if you hit much of a thick patch of grass this thing was going through foot tall lawn like it was nothing. Can't wait to get it right.
