Lawn Boy F series (7268) governor spring presetting
Jean-Marc
Hello Everybody
My first post !
I am rebuilding the carburetor on my 7268 Lawn Boy (F series ) Can anybody tell me how to preset the governor spring before setting the exact RPM; the manual is not really clear on this ; My carb is with the round collar adj. on the air-vane ;Actually i just want to know how to install the spring referring to the slots holding the spring, and after, how many clicks clockwise to preset , before final adj for around 3200 RPM . Thanks for your help .
I've had pretty good luck by initially setting it with the shroud off and engine not running (of course) by adjusting spring tension so the spring can just barely move the vane all the way open, then maybe one click harder to the wide open stop. Move the vane with your finger to various spots and make sure the spring can still move it all the way wide open. If it doesn't have enough reverse tension to move it wide open, give a click until it can (this will not be very many clicks unless you assembled it wrong). With this light preset, any engine speed will reduce the throttle (so it won't run wide open when you start it) and you'll have maximum range of movement. You can then tighten it further to increase engine speed.
It's a pain to adjust it after it's all back together, and dangerous to do it while it's running, so getting it as close as you can before you put the shroud back on is worth the effort.
Sounds excellent Sir ! I will try this out , Many Thanks for your help, very much appreciated .JM
