Lawn Boy 8430
doug22
I have a 1986 Lawn Boy 8430 commercial grade mower with a leaking carburetor. I believe a bad gasket.
How do I remove the carb. from this mower ?
Does anyone have a PDF copy of the service manual for this mower that they can forward to me ?
Thanks !!
Late to the show here. But if that is the two stroke with a Walbro carb be very careful with the governor spring that connects the throttle shaft with the operating lever. Easy to miss this and if it gets bent out of shape or installed wrong it's really hard to get it right again.
