ralphewycoff
- Apr 13, 2015
- 1
The Lawn-Boy 10730 comes from the oldest brand in lawn mower market since 1934. This brand brings lots of devices or machines with high quality and reasonable prices. Additionally, it also gives easy and simple features that produce an excellent performance in cutting the grass. So, do you want to own this gas lawn mower? In order to help you comprehend thoroughly, we will present a detailed review about this product so that you can think and then make up your mind.
A brief description about features of Lawn-Boy 10730
This gas mower is equipped with a Kohler OHV 6.5/144 cc engine that might work well with the thick grass. It also helps you accomplish the task soon in case that you豎*e busy and don遞 have enough time to mow.
With a 21-inch wide steel cutting deck, the mower will handle large paths in your lawn well. Relying on that, you might save too much time and then do other things. In addition, the deck might be adapted on a single side, so you don遞 need to adapt all of the 4 wheels individually.
Interestingly, this product comes with a 3-in-1 option. That means you might dispose the clippings via mulching, the side chute, or with a rear bag. Depending on the type of grass, you have a chance to choose the suited option. For instance, if you wish to mulch the clippings, its tri-cut blade will carry out the task excellently because the clippings will be cut multiple times before returning to the lawn. Owing to that, they are quite small, hard-to-notice, and quick-to-decompose.
Basically, this machine has some similar features to the Lawn-Boy 10732 gas self-propelled mower. Nonetheless, it isn遞 equipped with the self-propelled feature. Thus, their rear wheels are designed 11-inch so that you might feel smooth when pushing it.
Wonderfully, you can receive an awesome warranty for this mower. With a 3-year Tru-Start commitment and a 2-year No Worry Warranty, your machine will be replaced any part for free within 3 years. How such a terrific thing it is! (read more: lawn mower reviews)
