Lawn Boy 10552 Where Does Primer Line Attach
chuterman
Found a recoil starter to fit my Gold Series 10552. When I removed the cover the primer hose detached from the carburetor. Can't find info anwhere on where the primer hose attaches. Thanks for the help
Chuter
hotajax
Did you find out what you need?
viperv10
Hello,
The primer hose connects to the top right side of the carb if you are standing at the back of the mower.
The little tube inlet goes straight up and down vertically. It is just inboard of the gas line tube connection that is horizontal.
So if you get down mower level and look at where the gas line from the tank goes into the carb you should be able to see the primer nipple
sticking up. Hope this helps.
Jerry
hotajax
I like it when the nipples stick up
