msupercharger
- Jul 23, 2018
- 2
- 5
I moved this thread over here where it belongs...Any of you heard of, or seen this conversion done? I got really lucky and got all the parts together (have spares too including starter w/mounting bracket,alternators,2 or 3 electronics cup packs and flywheel brake assemblies,all of it except the battery.I will get that based on what will fit the box.I forgot to check the exhaust side of the block to see if the drilled post is there for the starter pin to anchor into.The molded block is there in the correct spot on the muffler plate for the lower starter anchor bracket,it is just not drilled or tapped for the anchor bolt itself.I sat I forgot to look because the mower is at the Service Dealer at present for carburetor cleaning and kit and I don't have the time or proper tools for this attempted conversion.Luckily I have my 10682 Insight as a standby:tongue:
Would love to see your comments and or suggestions! I am going nuts waiting to hear from the Dealer:confused2:
Mike
Mike
