lawn boy 10313 serial 7900258 need help with card linkeage
Gadgeeets
  • / lawn boy 10313 serial 7900258 need help with card linkeage
I have a lawn boy model number 10313 serial 7900258 and I changed the carb but I forgot to take a picture of the linkage and can't figure out where they go any pictures would help a lot thanks
BlazNT
Patients and you will get help. Do not post multiple times for the same problem.
Three threads asking for the same thing in 24 hours?? Patience not high on your part. If you want carb linkage, why not post the engine numbers, not mower numbers?? You have a TVS120-66004A which would have gotten you an answer after your first thread. Do you realize that out of all the members on this forum, only about a dozen are repair techs and have jobs to put food on the table. This forum is our way to give back, but on our time. This manual should help you out. Read the section on carbs and governors.
http://www.mymowerparts.com/pdf/Tec...L-2-CYCLE-TVS-TVXL-HXL-HSK-840-850-694988.pdf
Gadgeeets
sorry about the reposts I thought I edited the first one
thanks
Gadgeeets
also I have a Tecumseh 632795a carburetor
on a 4cyl engine
