Larger front tires
Raybay
I put larger front tires on my craftsman pro and what a difference they work great ? went from 16x6.50-8 to 18x7.50-8 they raised the front up 11/4”
logert gogert
its probably messing with the cutting angle, being that its now almost 3 inches taller, probably shouldn't be to much of a difference but you might notice it cut a bit different.
manufactures usually put the certain very specific parts on it because its what best suited for the mowers needs, now you have altered that so you'll probably have to adjust the deck.
Raybay
It only lifted the front 1 1/4” so should not make much difference I have a 54” deck and not much lawn yet so pull this trailer around for now
logert gogert
oh....oops thats my dumb self ?
btw welcome to the forum
That’s about right, what Logert doesn’t realize is that you added 2”, but that’s 1” on top and 1” on bottom. If you have the clearance to the frame, the only problem would be turning radius and easy.
logert gogert
yeah....i noticed that after awhile and i was like.." oohooohhhh, shoot, the rim goes in the middle, so that 2 inches is proportioned through out the height of the tire."
so once again thats my dumb self...sorry.
once again i didn't engage my brain before i spoke.
but don't worry rivets, I'm still trying.......slowly but surely.
Raybay
The tires did not hit anywhere
cruzenmike
Either way, you have altered the rake of the deck by lifting up the front end. This rake is important to air flow and cut quality. If a mower is typically designed to have the back of the deck 1/4 - 3/4" higher in the back and you raise your mower almost 2" in the front, it is certain that you have changed the performance of the mowing deck. I would suggest pulling out the manual and performing both a side to side and a front to back deck leveling. This will ensure that you maintain the desired deck rake.
