Lady tiger
Ladytiger
I have a RZT42 Cub cadet, blades will not engage-have replace PTO and got a new CAA 350 battery, checked for broken wiring. When problem started the mower would mower in reverse but not forward after replace PTO switch won't do either. Any idea what else I might check.
motoman
lady, Have you checked your model wiring against the factory schematics to make sure it is hooked up correctly? Have you checked the transmission linkage to see if it is broken or loose? Respon with more detail so people can help you.:smile:
