Thanks for idea but not a spark problem, it's does start and run when fuel put in carb,there is fuel in float bowl but for some reason not going throw carbSounds like a no spark issue then. There is a park brake switch that might possibly be bad.
There is also a controller by the steering wheel under the cover panel that can go bad that won't allow any spark.
