LA115 trans oil leak
cbs123
Hey guys,
I've got a John Deere LA115 in the shop with a transmission oil leak. It appears it's leaking out of right side axle seal and possibly the input shaft seal on top. It's a tuff-torq transmission. I do notice a *slight* up/down play in the axle also. Very slight. There is an axle bushing listed in the parts diagram.
I found where I can get the seals pretty cheap, but don't want to have it only last a short time and leak again. Don't want a "come back" Don't really want to split the cases either though
Just curious if anyone on here has went down this road on here before? What was the outcome?
Thanks
