La 135 mower
Tonycone
La 135 mower stops turning when I lower it below 3”. Any suggestions?
Com,on Tony give us a break. Your description of the problem could be the result of a hundred different flaws. Give us a better picture of what is going on. We are not standing next to you, with a beer in hand to see what is going on. When you say “stops turning” do you mean engine or blades? What have you done to solve the problem? Did it just start happening? When was the last time it was serviced? Does this happen at all speeds? What are your cutting conditions? These are just a few of the questions we have for you. If you would like us to help you, you need to help us.
