LA 130 Ignition Switch Question
carltondhouston
Hi All,
I think I know the answer but just to be sure... I have an LA130 I bought new back when it was new and I love the thing just fine. But today when it finally quit raining after forever, I tried to get out and cut the grass and the mower wouldn't start.
In the past when it would not start I would tap the solenoid lightly with a screw driver or my closed pocket knife and it would shake loose. This time though I realized the maintenance reminder wasn't turning on. I went ahead and shorted between the two big posts on the solenoid and the engine turned over nice and strong but there was no fire. So I suspect the ignition switch.
Headlights would burn nice and bright when I switched the key to that position.
I removed the switch and tested with a meter between each terminal. I don't have a wiring diagram so I just made a chart. It turned out pretty simple and I think it means the switch is bad.
There are seven terminals on the switch. When I move the key to from off to Lights, terminals A1 and B are connected along with L and A2. When I turn the key to run, I lose the L to A2 connection.
I grew an extra six hands and somehow figured out that when I turn the key to start, I pick up connectivity between A1, S and B.
I never seem to get anything on the G or M post. It seems like that might mean some kind of ground and maintenance thing? Just guessing.
Can you folks help me understand if I need to replace the switch?
I thought about just ordering that and a new solenoid.
I've done more oil changes and babying of this thing than is called for, just in case someone wants to bring that up. I'm pretty good about that stuff if I do say so myself. :)
Thank you for your time and attention!
M is for Magneto and G is for ground. You should have continuity between those two when the key is in the off position. If no continuity it should start but you can't shut if off. All the other positions seem like they are working correctly.
carltondhouston
That is great help. I did not check the continuity with the switch off, but that makes sense. Thank you very much for your help!
