That is a pulley guard. I thought that was what you were talking about but I had to make sure. Is it possible to open them up a little when installing them? Also they are not nessary. It is a John Deere will not get sued if these are installed. I run my mower without them. All they do on my mower is collect grass. This should go without saying but if you remove them make sure the blades are not moving before you dismount your mower.
