Jgraves121
Good evening, while cutting my mower made a loud popping noise and shut off. Removed the spark plug and was able to move the flywheel by hand. Put everything back together and it tried to crank it and it shut off again. Now I can't move the fly wheel at all.....and I'm a big guy. I did notice the key appears to be sheared, but would that cause the flywheel to move at all? Or is there a larger problem that will be found once I take the flywheel off? Thanks for your help......
