R rmd1960 Forum Newbie Apr 28, 2012 #1 The control levers feel like they may have some slack between forward and reverse. Hard to mow a perfectly straight line and jerky in the turns. Replaced all fluids and filters. Checked and fluids are all topped off just right.
R rmd1960 Forum Newbie May 2, 2012 #3 no, only have mowed with a snapper 52" ZTR. It is slow but smooth as silk.
S slc10844 Member May 7, 2012 #4 Lift the seat and check the dampers on the linkage. Had the same problem when a clip fell out of one of mine and the damper disconnected.
