Kubota zd323 Mower will not shut off
joe1986
The other day when I went to shut my mower off, I turned the key off and it would not shut off. The fuel shut off solenoid plunger is not plunging toward the radiator in order to shut the engine off. How can I test the power supply for the solenoid to make sure it is getting the correct voltage, and what voltage should it be getting? Also, how can i test the solenoid to make sure it is working?
Thanks,
Joe
