Kubota ZD 1211
Dirt Squirt
When mowing the grass the height is set on 3 and start moving the setting goes down to 2 all by itself self. Seems like it’s not locking in place. Any suggestions on why could cause this?
That’s frustrating. Does it drop right away when you hit a bump, or only after mowing for a while? I’d probably start by looking at the height lever and the pin or notch that holds it in place.
