Kubota TG1860G Shuts off after running about 4 or 5 minutes. Let it sit for a couple minutes and fires back up till it shuts down after another 4 or 5 minutes. When it acts up you can keep it running with carb cleaner so I am sure its a fuel issue.
Tank, lines and filter are good. I even ran it with fuel cap off in case it wasn't venting properly.
I have 12 volts to the fuel shut off solenoid and even ran a separate 12 wire to it when it acts up and doesn't make a difference.
Not sure the best way to check the fuel pump but one would think it works or it don't and not intermittently. Any ideas or bulletins?
