I was just wondering who has purchased the Kommander? What are your thoughts on it and if you had to buy again would you still choose the Kommander?
Krac....
You prolly have read enough of my comments...STILL loving the machine. It does not feel like some consumer grade unit, at 750lbs this is a beast and the power it has is simply great. Feels like I really bought something well built.
One of the things that matters the most is...THE CUT. Made my old field look like the front lawn. AND HAS CUT MY MOWING TIME DOWN BY AT LEAST by 1/3.
I get about 3.9hrs to the tank full, which I think is great for how much I get done. I think that is less than I use to get out of my old LX-188.
FWIW...One thing that I would add into the cost and something I did not consider... is a lift.
THE ONLY THING...those blades are loud...at least to me. Three heavy blades at 1800+ rpm they are going to make a few extra db's. BUT I DON"T CARE.
Stay safe,
Mike
Are you talking about the deck assist lift?...If you are...I have read that they are not worth it
I have the ZG127S and starting it is the problem. It seems the injector at the bottom of the Carb is always sticking and have to take it apart to loosen the needle which is a pain. Any solutions that you know of to solve this problem. I only have 17 hours on the mower right now.
