Does anyone have any experience or knowledge on how to "safely" remove the mower deck for cleaning and maintenance on a Kubota Kommander Z121S equipped with the K-Lift system?
I managed to get the deck off and back on but because the K-Lift system is under constant torsional strain it was difficult and there was danger of jamming fingers in the area where the lift clips to the deck. I could not find an easy way to relieve this pressure for deck removal. Even with the deck fully lowered, once the pins were removed the k-lift system turned upwards under pressure. I there a way to relieve the tension on the K-Lift?
