Kubota gr2100 blades will not engage
nixkar
Hi Everyone: I have a Kubota gr2100, the blades will not engage. Thought it might be a safety issue. I did change all fuses and slow blow fuse, had some issues with tractor not turning off with key or when getting off seat. Those problems are fixed but now have the blade issue.
Karen
Google: troubleshooting pto clutch on kubota gr2100, scroll down page to 4th entry titled:{ PDF GR2100EC } click on this site for workshop manual. Check condition of mower belt & idler pulleys, replace as necessary. See page 2-M13 in manual.
See page 2-S3, Mower PTO Section for probable cause, solution, & reference page. Also see page 2-S13 & 2-S14 & check PTO switch, item 1 at top of page, connection. Inspect wiring & switch. Page 7-S10 testing PTO switch. Messicks has good parts prices for your Kubota.
