gaudonville
- Apr 13, 2014
- 1
- 1
Hi
I have a Kubota G18 which is 10 years old. The lever on the RHS of the driver which sets the blades into rotation mode will not stay completely in the off (it moves maybe a half inch from the back position by itself) and activates the safety switch so that I cannot get off the mower when the engine is running (it stops because the seat switch is not made).
I obviously need to reset the position of this lever and also check whether the switch has maybe come loose. I din't want to strip the machine down more than necessary to do these things!
Can anybody explain how the mechanism is connected and where is the micro-switch which is cutting the motor please?
Cheers
Dave
Cheers
Dave
