Kubota 27hp Kohler runs perfect then just cuts off
cliffh
It will always crank right back up and run for however long it wants too. I cut almost two acres today having to recrank four or five times. Just wondering what can cause this problem?
MowLife
Make sure your fuel tank is venting.
geelee
if that's a zero turn ive seen the parking brake stick right at the point of safety switch activating. try manually pulling the brake all the way back next time and see if the problem stops, if it does repair the sticking brake.
