how do you prime the diesel eng
K krusey59 Forum Newbie Joined Oct 6, 2015 Threads 2 Messages 2 Oct 6, 2015 / krusey59 #1 how do you prime the diesel eng
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,482 Oct 13, 2015 / krusey59 #2 Fill fuel filter with clean diesel fuel & pump primer pump if you have one, crack injector lines loose just a little & give it a try, after she gets going tighten injector lines.
