Kohler twin Courage 23 starting problems
Gerry123
Kohler Courage 23 Model SV720S
Engine locks up during starting , after many clicks on the starter , engine will turn one turn
and then lock up again . After many tries , starts and runs perfectly. New battery has been installed .
Is there a valve stetting to release compression or is there a decompresser build in (could possibly be starter have not checked starter yet ) wondering if there is something simple prior to pulling starter , and doing a rebuild on it .
Don't pull the starter unless you have extra money to spend. Use the manual posted and check and adjust the valve clearances following the procedure. When you do so allot at least one hour of your time and go very slow, double and triple checking everything thing you do. Until you are positive everything is correct.
