Kohler sv600
Qtschmidt
As everyone here knows this engine has issues with the crankcases . I have four engines I am going to try to build one good engine out of the 4 I have . Two of the engines have holes in the cases the other two broken parts inside . What are common issues with these engines ?
Cover bolts not torqued properly at the factory and coming loose, leading to cracked blocks. There has been problems with camshafts on some engines, and well as the support rod for the counterweight breaking causing the back of the block to get broken.
