Hello,
I have a 1 year old troy bilt sv530 with the 17hp kohler that would not start will so I checked the exhaust valve and found it broken. I replaced it and turned the engine over and checked clearance and seemed to be perfect. I started it and it ran about 5 minutes before the same problem with a broken exhaust rocker. Manually it seems to work perfect. What is causing this unit to eat rockers?
