Kohler PH-XT149-0225 will not stay running.
Ocean56
I have replaced the plug, cleaned the carb with carb cleaner (I did not soak it or take it off), made sure I had new gas, made sure the gas cap is vented, and replaced the fuel line.
It will start, run for a few seconds, then shut off.
Any ideas appreciated. Thanks!
Scrubcadet10
Moderator
Staff member
You need to take the carburetor off and deep clean it, spray out the jets.
It's most likely a clogged jet.
