So I have an older exmark machine with a Kohler engine on it. I have no clue the year or make of either since the moron I bought it from painted over everything.
The problem I am having is this. The mower runs but almost dies out every few seconds and then backfires. It does not die completely after backfiring it boosts back up and runs. I changed the plug, air filter, fuel filter, cleaned the carb new gas tank cap. Motor completely dies when I engage the blades too.
Mower has sat for two years only being started once every couple of months. I went to use it on an account the other day and was fortunate enough to get the entire backyard done without any problems. After that it died out and I used another mower to finish the front yard. I was fortunate enough to get it started so I could get it back on the truck but it is not running any better after all the tune up stuff.
Any ideas would be great! Oh yeah, I ran some seafoam thru it today too and did not help. How much of that am I supposed to use? Can it be dumped right into the gas? I was just pouring it down the air filter assembly like you would starter fluid and letting it run through like the can said. Thanks in advance.
