Rokon
- Apr 7, 2012
- 164
At idle the engine slows down and picks up (surges). Full throttle there is an intermittent miss, and does not feel as strong as a 26hp twin should. If blades are engaged fuel spray coughs out the carburetor and it chugs down and dies. It will start back up, but repeats itself if tested under load.
Cleaned the carb twice, installed new plugs, comp tested, tested the coils for spark at cranking and at running speeds, all passed. However on the leak down test hot, I could hear a little bit of air escaping through the carb. There is no valve adjustment on these because it's a hydraulic lifter design.
This engine has the standard ignition. No DSAM system.
